- Jan 14, 2011
- Gillette, Wyo.
Yep, gotta get more outputs in before bias is right. Ok, now, go directly into the AC mains, check DC offset on both channels...
Once again now I am starting to understand ! Left channel =12.3 mV Right channel=1.4 mVYep, gotta get more outputs in before bias is right. Ok, now, go directly into the AC mains, check DC offset on both channels...
No shit right ! I damn sure made a mess of that last time. Thanks for the reminder.Remember don't OVERTIGHTEN the outputs...
Ok, do that row and call it good, after you have the 3rd row in an checked on n dbt and variac, check on ac sins and see if it will bias up to 350 and check DC offset one more time..lol check back when I get up at 5...
Glad you like the numbers, I sure do. Got 200 T-03 insulators (Mica) on the way from Texas. I will not run out again in this lifetime. I am going to pull 4 from another amp that croaked here in just a bit if I cannot find any others and get them ready to install as per your instruction.
Time to pick out your test tunes?
Is that even possible?? Sabbath at low levels??????????????????????
