- Jan 14, 2011
- Gillette, Wyo.
Beaty big and bouncy..
I thought the same thing!“Compact”? What does the full size one look like?
my hero!!!Designed by Rube Goldberg!
I love my PX-3 it sounds wonderful and just fun to watch it work. Still using the original cart, what do you have in yours?IT'S BAAACK!!!!
My PX-3's tonearm stopped tracking several, probably 15 years ago. Button functions had started acting intermittently at first and then totally dead. Very frustrating as I've owned this TT since new in the early 80's and it had been rock solid. I looked for advice online but none of the symptoms were quite like ones people were describing. I started down the path of restoring and flipping the rubber belt...and that led nowhere as the issue was with the belt's motor drive mechanism being stuck. My debug skills and time to work on it were non-existent, so into the corner it went until a few weeks ago.
I obtained the limited service guide, which had a detailed schematic ... verified the photosensors seemed to be doing their job, apparently a common failure item. I drilled into the cad cell sensor circuit as the arm was not advancing into the record grooves. I measure transistor voltages and compared to the schematic ... some were close while others were way off. Cross-referenced the old Japanese transistor part numbers to current products, figured I might as well do the diodes, replaced the push-button switches and electrolytic caps. Turns out 4 of the transistors I measured with odd values, so they were suspected as they had apparently gone out of spec, since they did not come up as dead.
Back in business!
Went ahead with doing all of the transistors, diodes and electrolytic caps, and then calibrated the DC balance and Tonearm Angle adjustment.
Works perfectly now!
IT'S BAAACK!!!!
Back in business!
For now, I reinstalled the Ortofon MC10 cartridge that I bought new with the turntable (back around '81 or '82). Flip-down dust shield removed for better clarity. It was my first MC type, and I believe it was Ortofon's entry-level MC at the time. It came with the matching transformer that seemed to work well with the PL 2000-II that was paired with the 400-II and formed the core of my system at that time.I love my PX-3 it sounds wonderful and just fun to watch it work. Still using the original cart, what do you have in yours?
fascinating!!!For now, I reinstalled the Ortofon MC10 cartridge that I bought new with the turntable (back around '81 or '82). Flip-down dust shield removed for better clarity. It was my first MC type, and I believe it was Ortofon's entry-level MC at the time. It came with the matching transformer that seemed to work well with the PL 2000-II that was paired with the 400-II and formed the core of my system at that time.
I should also note that the speakers I used back then were also made by Ortofon, their top of the line at that time, Model 445 that boasted a pair of 8" woofers, mid and tweeter - as well as 2 aperiodic ports for the woofers. The drivers were made by Scan-Speak, a relatively newcomer at that time, so I have been told. I still have the speakers in use in the garage system ... still sound fine, but pale in comparison to the a/d/s/ L1230 that are on the main system now.
Attached some pictures of the teardown and repair...note the rubber belts were in very good shape, so I flipped them over as they had some "memory" bends from the spindles. Also reconditioned the rubber with "Gummy Pfledge" ... BMW guys know about this magical stuff!
Glen is working on a cool phono preamp for MC and MM cartridges ... he gave me the motivation to reopen this old turntable. Onward to building the same preamp he has started!
I second that motion...I have tested many transistors. Even if they pass the diode junction test, they can have ZERO gain..
