- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
Max output now a respectable 505 a side...
Whew.. excellent!
Reinstalled D9, offset is now steady at .008. right side at .011 Back on the AP...
negative .008 and negative 011?
Correct that, my damn losad switch was intermittent, 471, 472....max out, both loaded and driven...
Yep it's F*&^%$ with me once to ofteh, also had a bad test cable, tetally no carry through. Was a solid wire coax that couln't take it I guess. I have since found some excellent mic cable I'm gonna have to make some out of....
The 700 does bass transients MUCH better, but for anything Mach 4 and below, it's a tossup now....
Yes Joe. Beern listening to the 400 all morning and afternoon.. Just put the 700 on awhile ago, and you can sense the headroom in the 700. As far as the sound goes the 700 appears to be a little boomier in the bass department with the 400 slightly tighter, that's about it....both ae crystal clear....
Yes I did Joe, and did not lose Q7 when the rail fuse went.
My 700 is up and warming up for final bias setting now. It was an uneventful bring up so far (I like them that way). Overall, I am very pleased with how this kit turned out but it is a lot of work (or maybe it was the side projects in between starting and finishing that made it seem longer)
It was about half the work of redoing the entire back wall wiring that I had done on that earlier 700.
You made the final change recommendations correct (R35 and the PAD3 connection point)??
My residual was 1.2mv and .980mv. You??
Not there yet Lee. I need to put all the skins on it to get that.
Took a rail fuse out one more time before I changed out the BR butr after the R35, and Pad 3 change.
