Russ' Phase Linear 700B Going Fully Comp!!!!!!!
After all day of listening I ended todays listening session with all of "Museum of Consciousness" and the last-----God Particle-----and THAT Ladies and Gentlemen was almost a religious experience......
I am absolutely flabbergasted by how the K's sound now, how could I have been such an idiot for soooooooo long!
kevin
Forum Veteran and Hillbilly
Wise VA
Hard to believe they sound that much better !!!! Im just going to have to come out there and listen for my self !!!! Give me about three weeks and I will knock on your door !!!!
James Burke and Mark Skradsi----you guys heard the compromised version of the K's. You would not believe how different they sound now.. they are so powerful they push themselves out of the corner...
Tales of the Inexpressible we hit 130DB.....with negligle compression. I believe if run long enough the structural integrity of the house will be threatened......
Yep, not longer than 10 minutes at a time and I don't ever clean the earwax out, ------tympanic dampning---
There's a little buzz when I input 2 volts or so..............on idle with nothing playing....and really all I'm doing there is amplifying the pre-amp residual...
NavLinear
I like you Lee can hear nothing and I mean nothing through the speakers with no input.
That is amazing Joe - of course I'm assuming that you have the volume turned up. :shock:
When you're measuring noise in microvolts or fractions thereof can it get any better? Great job on the design and implementation of the hardware.
But of course :)
I think I can get my residual noise meter readings lower if I get rid of the original low grade shielded cable and improve that wiring..
Other than knowing that there is huge headroom there Lee, the sound is quite similar to the FC 400. It is hard to distinguish the difference at realistic listening levels. Through my Dynaco A25s the 700 sounds a slight bit smoother than the 400 but very, very close. I cannot wail on these like you can wail on the K's that you have Lee.
After Johan's, THAT will be an interesting build, more power less noise, STIFF power supply. I'm gonna enjoy that one. I'm short 2 700B chassis though.....Thanks Dennis...
Joe, I'm amazed these K's can do what they do, I'm seriously worried about the house, I mean shit MOVES!! Floor joists, studs, you name it.
There's some folks in Denver gonna get their shit BLOWN away in October....
I think I could pick out which is which in a blind test but I'd hate to risk money on it. I'm glad to see you came to the same conclusions about em. I'm NOT nuts....either that or you are too....
