- Jan 14, 2011
- Gillette, Wyo.
Also Chas, I held up on sending the 2SD555's for this. You'd be better off going with the MJ 21196's for this project.
I did not replace Z1. I'm waiting on one now, hoping that will fix it.
I don't see a question asked by anyone named Joe.
Q1 MPS-a93
Q2 2N3415
Q3 2N3440
Q4 MJE15050G
Q7 BC337
Q8 BC 327
Q9 MJE15031G
that is bad advice they gave youYes, that should be 30, not 50. Those were the parts supplied in the qua-co rebuild kit, which was put together specifically for this amp.
q5/6 and q10/11 are the original 2sd555 and 2sb600 drivers. I have one complete good set , so I can test one channel at a time.
Charles.
Charles.
Hi Charles
As Lee has advised, the MJ21195/MJ21196 transistors are far superior to the original 555/600 complements in every aspect.
I don't care, I don't want to spend a lot of money on this hunk of junk until it is working. And even then, I already have a 200 amplifier, this will be a backup.
Charles.
So if I have one good, perfectly working channel, and one bad channel, what differences should I be looking for to narrow down the bad component(s) on the other board? Right channel is giving similar issues, negative rail on output, with our without power transistors installed. However, the difference here is a dim bulb tester lights briefly and then goes dark. Before I finally fixed the left channel, the left channel caused the tester to to burn brightly.
Charles.
