Well, I want to thank everyone that helped. I finally got the left channel working. The problem was Q8. It was causing excessive current to be drawn, which blew out Q2.
That channel is working now, and now that I have one working channel, I should be able to get the other working, since I have something to compare it to.
As for the 2SD555's... I'm not sure how you equate replacing them as costing only $12. The way I understand it, I can't just replace the two 2SD555s, I also have to replace the 2SB600s. And I can't just replace them in one channel, I have to replace them in both. Which is going to be more than $12. What's more, the market is glutted with counterfeit semiconductors. So I was hoping to get two known good replacements from a reputable source, and not have to worry about buying 8 new transistors and maybe getting stiffed with fake chinese parts. What's more, I also understand there are serious oscillation issues with some of these replacement semiconductors, and I want to avoid that completely, because I don't have any way to test for or correct oscillations.
Anyhow, I just put a bid on some 2SD555s on eBay. Hopefully I'll be able to snag them for a reasonable price, take the two I need, and then resell the rest.
Again, thanks for all the help so far. I've got some parts to order now, but I'll post back when I get the right channel working as well.
Charles.
