Methinks you've read comments about 6 inch pumps here before..
I have seen Jason in 6" pumps, the beard kills it though LMAO
Thank God Joe was on this project and not that guy!!!!
Przem...do youy have a DMM?? If so check your voltage between one of you hot leads and ground coming out of the wall....if it reads anything close to 120 that would sure be another way to wire the fan and keep a lot of AC wiring away from the low signal stuff.....
Hey Lee on Przem's 700II, are you leaving the l.e.d.'s or changing out the faceplate and going with the 700b meters? Could this be done to Pl700II's?
If leaving the l.e.d.'s, could you change the color other than red? Reminds me of vampire lights on all the new stuff.
Przems is going back stock....but yes you can go with a "B" faceplate and meters, chassis is the same...
Somebody mentioned awhile back they look like Cylons with the red....I don't know if you can change colors, after looking at em, I don't think so ....
So are new "B" faceplates in the works yet? Count me in. What about meters? I'm sure that has been addressed already?
You just need to find berthas sister and you'll be set. She's a looker!! Lmfao
Yes faceplates are in the works, the meters are still a problem.....lotsa stuff going on behind the scenes...always.....Joe is never satisfied.....
I know its 230 Przem, which means it should be 115 between one leg and ground....
It's funny I just noticed yesterday that there was a outlet on the back of Jessica!! Is it even hooked up??
