PL7000S2
Got the transport apart.
Can see where they shoved black moly grease into it from the front at some point.
Original grease is clearly Lubriplate like white lithium.
Plastics look good.
Going to get this stuff cleaned and bagged.
Plastics look good.
I wonder what this extra part is :-)
Good stuff George...
Yup, took lots of photos as I disassembled it!
Luckily all the clips and screws are standardized so they don't have to be kept in order, they'll go into one Ziploc.
I'll contact Terry's Rubber Rollers in the next couple days and see about getting the pinch rollers and idler tire rubber replaced.
There's also several rectangular rubber slip on brake pads that need replaced. If he can't do those then I need to search for neoprene tubing or perhaps heat shrink.
I'll post a photo later and ask for ideas about best way to go.
Plastics look good.
Not for the faint of heart...
Mocking up the transport and measuring for belts using hemp twine(of course!).
There are no good belt kits available for this model, so I'll measure and order a small range of sizes.
Additionally, there is no info anywhere about the idler tire. But, I have it removed from the pulley, so should be able to find one.
Decided to not use Lubriplate. Good for motor assembly, but I've seen it separate and run in bicycle hubs and bottom brackets.
Using what I consider the best bicycle grease by far, Park Tools PolyLube 1000. Really good stuff.
For oil, Mobil 1 of course. Right out of the jug in the garage. 5W30, it'll work fine.
I did shoot Terry a email and photo of the pinch rollers. He did quote me a price. Very expensive.
I need to get it done regardless, as the originals have no apparent wear in the bushings, and yes, they're rock hard.
Found some very minor cracking around the nylon pulleys that are press fit on the reel shafts. The nylon slightly shrinks as it ages.
Need magnification to really see it.
Have some 3M nylon structural adhesive coming.
I'll fill those small cavities between the hub and the rim on both sides. Should never have a issue with those very small cracks.
I'll use a moderate amount to keep the weight down and keep it balanced. Shouldn't be a issue as the direct drive motor and flywheel are massive.
The felt clutches look very good. I'll leave as is. If I find issue, McMaster Carr sells sheets and washers.
In-between the reel assemblies is the idler pulley/clutch and dismounted tire. Can't find a single photo of it anywhere, so perhaps this is the first. Distinctly different from the CT-F1250 version and it's ills. This one looks good.
Cleaning and oiling the direct drive AC motor.
No wear or dirt, but it's very dry, no lube at all.
Need to figure out how to get into the Canon Seiko DC motor next. They made it totally tamper proof.
Got the DC motor opened damage free.
As installed it had a black rubber "condom" over it to absorb vibration.
It was totally degraded, so I'll replace it with bicycle intertube.:)
Got the red cap off by putting a safety razor blade between it and the housing. Rolled while gently tapping with a hammer. Permanent magnets, so be very gentle. Then two blades, with prying, and finally a screwdriver.
Commutator and brushes look good. Very dry bushings.
Very strong magnets in the housing that'll grab the thrust washers. You'll have hell trying to find and remove them.
The set screw on the drive pulley is a 0.9 mm, way smaller then a 0.050".
Been reading about brake pads for several days.
The originals are in surprisingly good shape.
Still nice and pliable after cleaning.
Flipped them over and reinstalled them.
If I do need to replace them in the far future, think I'll use leather.
The nylon reel brake drums they contact are in good shape except for the micro cracking around the press fit. Should have that solved once the adhesive arrives.
10-4 on the acetone, I do have some sitting on the shelf and a good selection of sandpaper.
Have read the adhesive is stronger then the substrate, so I'm also going to watch for "melting" and heat on the test material.
This may end up being a bad idea, we'll see.
Got the adhesive, but after seeing the cartridge, going to wait until I get a cheap dual piston gun and mixing nozzles.
Got the nylon pulleys cleaned, sanded, and cleaned again. They'll sit under a halogen desk light today and bake to outgas, then I'll ziplock bag them.
No reason to rush this.
Got the new idler tire installed. It's a TurnTable Needles ST.670. It needs the sidewall sanded some as it's slightly too wide.
Perfect fit with a little bit of work.
