PL 700 Pro Build
Joe, O.K., so increase capacitance value to improve low frequency performance.
PL had two 2.2 uF electrolytics in series + to + on each output trace to create a bipolar.
Per the photograph of the old test board, a jumper replaced one cap and a 4.7 uF film the other old cap. This is how both working preamps are configured.
What should I study to figure out the optimum value for the output coupling caps. I'm at a loss for terminology and thinking I'm approaching the need of a good spectrum analyzer once again.
OH! I think I was looking at a configuration like this in an old Pioneer schematic or something.
Apparently, setting caps up this way, has some unique properties, compared to a single cap.
I have my popcorn, because I didn't understand it!
Hi George
The good news is that the move to the single 4.7uF has improved the situation ~5 fold from the original (1.1uF to 4.7uF)
You have to consider what you are driving, the PL amp input load with a RevG1. You indicated the measured impedance is 386 ohms at 50Hz which makes total sense given what you measured a decade above that at 500 Hz. Lets assume 25 Hz, your measured impedance should be somewhere around 772 ohms. Lets use that number. This means that your amp output at 25 Hz will be down approximately 1.5% from and equivalent signal at 500 Hz. Not huge but something.
Compare that to the original back to back 2.2uF situation and your 25 Hz signal would have been down ~6%. You have improved the situation significantly.
Hi George
Thanks Joe. I'm going to have to reread this several times and think about it to understand. I see I need to read up on capacitors and their effect on frequency. Thank you!
In the coupling application, where you want great low frequency coupling as well as high frequency coupling, bigger is better. Unlike solder connections where "the bigger the blob, the better the job" is not always the correct approach.
Joe, I installed the two TDK 22uF film output caps and wire jumpers in my PL2000 and the preamplifier sounds better than it ever has. I am quite sure the technology to create a 22uF film cap with 25mm lead spacing did not exist in 1979.
Mouser P/N 871-B32523R226M
I suspect it existed Mark but PL did not want to pay the freight for film caps of that size/value.
Panasonic and Kemet make nice film caps; the latter come quite tight on tolerance if you wish (some 1% films in the phono pre- long lead time). I ended up going with 2% ones due to the six month wait at that time. Paired them up and they are within 1%. Just get a few extras and they pair easily.
Snow day in NE Ohio, so pulled the 100k attenuators out of the 400 S2 WOPL that powers my biamp system. Installed 50k to match the 700 Pro 50k attenuators.
There's a lot about amp input impedance and it's effect on preamp output that I don't understand, but it makes sense to do this as the 700 seems to be more "sensitive" and have higher gain at the normal volumes I listen to. Need to get these balanced without going into the MiniDsp.
Very little readjustment to the Cylon meters was needed, which makes sense. What I've done is changed the input impedance that the preamp "sees". Haven't changed the ohm resistance through the coax from the RCA jack center conductor to the control board.
Success, makes a audible difference. Amps are now balanced. Easy to hear and see the difference on the Cylon meters. My two 400s and 700 were all built as similar as possible with Joe's WOAD parts, just needed to get the attenuators matched.
Going to do the 400 S1 WOPL after lunch.
So ran into a problem with the 400 S1 WOPL and 50k attenuators. At 40 VRMS output, the meters peg. With 100k attenuators the meters were perfectly aligned at 100% at 40 VRMS output.
I don't understand why the Cylon meters were still closely calibrated but the mechanical meters aren't. Going to open her back up, find the resistor on the WOAD light board for the meter, and install a decade resistance box to find the proper value. Get those new resistors installed and retest.
27k ohms puts the needle right at 100% at 40 VRMS output, which is 200 watts per Joe's tech documents. The WOAD light board has a 13.14k ohms resistor installed.
So, dropping the attenuator value by 50% requires doubling the resistor value to keep the mechanical meter calibrated.
Now to search for 27k resistors. Parts are not organized.
Got it calibrated. 27k ohm resistors with 50k ohm attenuators. Close enough for testing. The right meter is mechanically adjusted a little too tight and I'll back it off next time I go into it. Now it's time to close it up, plug it in, and listen to some Allman Bros for testing.
I use a DPDT toggle with resistors on the toggle and 0db can be 2 watts, 20 watts or 50 watts
Easy answer, the original light board calibration was for 100W at the 0dB setting on the meter. The new light board (LBC) provides 3 jumperable or switchable settings for the 0dB mark, 20W, 100W (to match the stock setting) or 200W. Ask Dave (Phase Linear Phanatic), he has several of the switchable light boards that he has installed with switches on the back to match his mood.
PS: the input pot value has nothing to do with this meter sensitivity setting.
You may now be disappointed that the analog needles do not move off of zero at most normal listening levels. All of my customer requests have been how do I make my PL400 needles move more at the levels I listen at? That led to the birth of the LBC light board.
The LED meter has a log amp in it to give you some sizzle at low listening levels while flattening out at higher volume levels. Analog meters don't do that.
