- Jan 14, 2011
- Gillette, Wyo.
Hookay....
I would not mind my CV A-2200 amp redone Ed, bet it would be a piece of cake for you. Has two separate preamp boards, it's a dual mono
That's only on the PL14 board.....
Lee, is this still so ? http://forums.phxaudiotape.com/showthread.php/2280-2N1304-2N1305-Transistor-Set Can these be bought for my board ? Do I need replace them, or not put them in at all ?? Possibility get some to keep in stock ? I would like to replace all the transistors on the board as well as the diodes and caps but when it comes to this beta testing / matching I have no real clue what to do. There is this guy on e bay that has all of them and says that they are already matched... https://www.ebay.com/itm/PHASE-LINE...490699?hash=item41dc55e40b:g:gesAAOxyaTxRQnHl Should I just buy these ?![]()
700HF (High Frequency) amps built for Bell Labs.
Backlanes won't fit, the Series 1's have a different bolt pattern for the outputs. You have to drill two holes to mount the driver board. You can, however, buy a new chassis and heatsink. The faceplate will fit...
Hey Ed,
What is the story behind the 700HF for Bell Labs? What makes the 700HF different / better / unique?
Nick
Lee, I was just refreshing my old brain and If I remember right, the reason I didn't buy an original 700 was the transformers had a different bolt pattern and would not fit the new chassis??? I recall something about the transformers. Hell, if the transformers fit the new chassis, that's half the battle (And all the money)..... But I think I remember that we figured out the transformer will not fit. Thanks
P
Hi Ed,Nick,
The Bell Labs 700HF's will meet spec (.25% THD) all the way to 100KHz at rated output. Albeit when you test them you can't hold them there for very long (just a few seconds or so/just long enough to verify that it meets spec) or you will start blowing the Zobel network and potentially the output transistors as well.
I have purchased (3) 700HF's over the years. The first one I acquired I either sold or gave to Dean. The second and third (which I purchased from someone who bought them at an estate sale in New Jersey) were sold to the same collector in Massachusetts.
I have a copy of the schematic. I am not sure if I have posted it on the Phoenix forum. I did provide copies to Lee and Joe. Would you like a copy? A number of parts were actually removed as well as some changes in the transistors.
According to Dean about a dozen or so were built. I have heard (3) variations to the story as to why they were built; 1.) Magnetic bubbles on tape. 2.) Underwater experiments with dolphins. 3.) Use at trade shows.
Ed
Anytime I see anyone on ebay selling matched transistors, I always want to know more about what means or methods they used. What voltage and current they used and the manufacturer and the model numbers of the test equipment they are using.
In the case of gain/beta matching of the pre-drivers (i.e. 2N3440 and 2N5415/6's), I am not sure that you will find any measurable improvements if you tested the amplifier to its manufacturer's claims.
In the case of the first and second differential pair transistors (i.e. TIS97 and MPSA93's), if you match the transistors, you will see a difference in: 1.) dc offset (albeit, as Lee has already mentioned the PL0171 pc board has adjustable dc offset trimpots) and 2.) turn-off thump. Lee has shared on the Phoenix forum a simple technique (I have seen best used for low power transistors) using a digital multimeter; measuring the transistor junction resistances and closely matching the results (between any two transistors) that works quite well. Perhaps Lee can provide a link to this technique.
Ed
