- Jan 14, 2011
- Gillette, Wyo.
We've seen what the ground bus became later, i'd be surprised if the hum shield started as that...
Hi Ed
Aluminum will not do much of anything for leakage magnetic flux, it will handily contain electrostatic fields however. In order to have aluminum be effective it has to be a canceling loop around the transformer leakage flux in which case it will generate an eddy current to cancel out the impinging magnetic field. But as an open plate, that circuit is not completed. Steel or MuMetal will contain magnetic flux fields by shunting those stray fields through the ferromagnetic material and then back to the source to complete the magnetic flux line.
Aluminum has a relative permeability of slightly over 1 (nearly the same as air), steel up to ~4000 and MuMetal in the ~18K range, Permalloy even higher. The more permeable, the better magnetic shield it is.
Would be interesting to see if the original PL700 hum shield makes any measurable difference, it would show how much electrostatic field is present. I often wondered if that aluminum plate was intended to be a ground bus or shield in the original 700.
Hope this makes sense.
Joe
Joe,
It all makes sense.
I am not sure how effective the aluminum "hum shield" was as a ground bus. There was also a small jumper wife between the ground terminals.
I will take some measurements once my wife gets off my back on selling the other mechanical/physical measurement and test equipment I brought to Connecticut.
Thanks!
Ed
I hate them jumper wifes...
Don't be hating on the jumper wifes. All good electronics techs need a jumper wife or two.
Ed,
My PL400 meter bezels say "KEN COX" on them next to "PHASE LINEAR" and "PART NO. 030-0235-0". Do you know who he was?
Mark
Hi Jim and All;
Thanks so much for your time and effort in contacting your transformer rewinding expert. The costs involved are understandably high and this is compounded by 2 way shipping costs. I have 4 PL700's of various vintages. They all have some degree of 'leakage'. I have not had this hum/buzz issue with the other amps. I have some further investigating to do regarding errors I may have made in rebuilding this latest PL700 II.
Also, I have some investigating to do regarding a standard for leakage tests. As mentioned, Joe found 32 VAC on his PL400 ( IIRC, chassis to line neutral with nothing else connected to the amp). If this leakage is from capacitance, rather than a resistance leak that might be the result of insulation break-down, I am concerned that rewinding may not resolve the issue. As Lee mentioned, the 700 II has a 12 VAC winding for the meters rather than the previous generations ( 6 V ) winding. Could this additional cramming of more winding into the same space result in more capacitance?
This is a test suggested on another forum;
"One way to simplify this would be to short the main primary wires together, short the secondary wires together, and then apply mains across the two with a 1 k resistor in series and connect your meter across the 1k resistor. Use your variac to gradually turn up the voltage. You should then get a decent leakage reading."
IMHO, having the windings shorted wound eliminate any induction influences and reveal only leakage from inter-winding capacitance and insulation breakdown issues. This test would require opening the amp and jumper-wives on the windings.
I have just rechecked my perfectly quiet WOPL'ed PL700B without shorting the windings but using a 1k ohm shunt to measure leakage: 43 VAC chassis to neutral---no inputs connected, no shunt
40 milli Volts with 1k shunt.
Strangely, there is 77 Volts on the chassis when the amp is switched off, dropping to 76 mVAC with 1k shunt.....and this is the quiet amp! If anyone could be persuaded, I would be very curious to see what voltage is measured on your PL700 amp, from chassis to neutral, with no inputs connected, with and without a 1k ohm shunt.
Thanks, all Peter in Canada
