I think Peter has grease and mica insulators.
It is apparent power, not real power (thus VA ratings, not Watt ratings). The magnetic flux in the core gives it back as the voltage decays. It is called the magnetic charging current.The transformer core was temporarily shimmed to isolate it from the chassis. IMAX film shims pictured. My analogue AC Ammeter on the variac read 230 mA at 120 VAC with only the bridge and snubbers connected.
Is this normal?
That's about 27 watts. The transformer should get fairly warm but it doesn't. I will leave it on for a couple of hours. If the transformer is more or less a pure inductor with no load on the secondary, does the current lag the voltage by 90 degrees and therefore not heat as much? I think I dozed off in class that day!
All may not be well;
With inputs wired as per WO schematic, sig gen and sacrificial speaker connected, there is a load hum. A slight tingle is felt when touching the chassis or heat fins. Measured approx 60 VAC to my building ground to chassis. Voltage decreases when I touch the chassis. The (leakage) is more or less the same, 10 volts less when I reverse the line cord polarity. Voltage (and hum) are gone when a jumper is connected from the chassis to a wall outlet ground.
The transformer bolts are still insulated from transformer lams and chassis. The transformer itself is not isolated from the chassis. That would possibly require shims between the cast end bell-capacitor saddle and the lamination stack-----if this is even a solution. I gather that it is a good practice to isolate the bolts (prevent eddy currents), but has anyone had to isolate the whole transformer from the chassis?
Fluke meter reads "infinity" from the primary windings to the chassis.
I will search this forum, but has anyone had experience with transformer trouble?
Thanks again, Peter
Hi Mark;
On my test bench, I am using the wall outlet ground as reference. The ground is several hundred milli-volts away from the neutral, depending on what's drawing current. I am former Theatre sound and projection installer, so understand the star-point grounding necessity. My home theatre rack is has one central ground lug. It is tied to the four-gang outlet box ground. The amplifiers are all mounted with insulating sleeves, washers, and shims. The PL's have always been a PITA to mount! I have been planning to run a direct number 10 ground wire to the hydro ground stake, about a 40 foot length but it hasn't been necessary so far. The system is dead quiet with 3000 watts of amplifier power at the ready.
I don't have access to Hi-pot testing I thought that my test results might give you an idea of the severity of the leakage. As mentioned; both series II amps involved in WOPL'ing are behaving the same. With nothing connected to the amps there is about 60 VAC from the chassis to the wall outlet ground. With the Fluke meter shunted by 1 meg, it drops to about 40 VAC. 10 k shunt drops it to 650 mV AC. My thinking is that grounding the chassis would solve this issue? Maybe just mounting them to the rack without isolation?
After all the output devices were installed, I was anxious to hear the amp produce a sound through a speaker. The amp's only connection to ground was the signal gen, and that was the INPUT ground. I could see this as the issue---huge hum and faint sine wave in the background. I will re-connect everything and try grounding the chassis for another speaker test. I actually had envisioned replacing the 6-32 screw for the single point chassis connection, with a 6-32 long stud to create an external ground connection.....Or running a wire from one of the speaker ground terminals to the rack star-point ground (some contradiction to the amp's internal star-point scheme with that brain-burp).
Just puzzled that no one has had this leakage issue, I will search this forum for anything relevant.
Happy New Year All!
PS; pictured is my quasi-comp 700B driving the mid-range line arrays, to be replaced by one of the WOPL'ed series II's.
The quasi 700B (you helped me fix the ringing problem) has a WO control board, 2012 vintage, not sure what rev. No hum issues but once accidentally plugged in the RCA cable with the amp on--I thought the voice coils were going to leave the building! I believe with the centre pin of the RCA plug making contact before the shell, wouldn't any free-floating leakage be interpreted as signal for that brief moment? Regardless, the amp is dead quiet with the only RCA lines in as ground connection. The amp is dead quiet but has the original PL ground scheme and I have bypassed the volume pots.
As asking if you measure any AC voltage on that chassis Peter.
