Peter S
Hi Joe,  they are  3 contact,   Tip, Ring,  Sleeve  (TRS).   All 3 contacts are insulated from the mounting hole.
			DBT = Dim Bulb Tester. I use one regularly. If you would like you can google "Dim Bulb Tester" and get a whole load of ideas to build one.Hi Folks; It's been a little while! I've taken Perry's advice and replaced all AGX fuse holders with new AGC holders. Yes, I could only find AGC 5 Amp fuses locally. I'm glad I did---found a second broken holder. I'm still far from bringing up even the back-planes but Joe mentions "bring up on DBT and Variac" several times...What is a DBT?
That was my daily dumb question.
Keep them separated if you have RevG1 and Backplanes installed.Sexy sexy! Look at those input jacks!.... Keeping it simple; the phone jack ring and sleeve connections have been connected together, but floating from the chassis.
Why is it necessary to connect the input grounds together at the jacks? Is this not a potential ground loop? Depending on the source equipment, wouldn't the ground be common in that unit?
Thanks for any opinions, I always seem to be rocking the boat.
PS: the amp with back-planes and bottom row of outputs (drivers) has been powered up. So far so good. WO rev G board to be installed next!
Super nice. I use all three. Ammeter, DBT and Veriac. I like the fact that the DBT is a good visual indicator as well as good at current limiting. Each to their own though. I watch mine like a hawk.I have built a Variac box with Volt and AC Amp meter and fuse. It has a switched shunt to increase the Ammeter FSD from 1 Amp, to approximately 3 Amps. I watch the current when powering up. I am inclined to believe that this is (an even better?) substitute for a DBT.
Perry, do you use an isolation transformer ?
Mine is old too. It just looks new.
Seeing those I'm embarrassed for my poor Variac.
My Veriac is so old it has no isolation built in. It adjusts voltage only that is why I asked.
LOL. That is how mine is set up. A really old veriac that I attached a modern digital volt/ammeter to. I have the DBT set up where I can use it in circuit or out. I just wondered if you were using an isolation transformer ahead of those.Using it to find faults is no problem. When you have Zero Volts, you have Zero current. As you turn it up off zero volts, you just monitor the current meter... If the current keeps creeping up, stop and turn it back down and troubleshoot your short... It doesn't get much simpler than that. Some of the guys here say you need a DBT AND a Variac.... Bullshit.... You can do it all with a Variac.... I know since I use it every day with the broke dick shit coming in the door.
