phase linear 400
before i turn off the soldering iron , george of the jungle....
will you tell me exactly what you did to connect your meters to the dcp board ???
i want to do that....when i first developed problems...and had dc on the outputs...
pegged the meters...i think that wont happen if hooked to dcp and it is functioning...
please....
thank you for all...
Remove your meter signal wires from the back wall or backplanes. Connect the right meter signal wire to the red speaker jack stud that's screwed to the DCP, and the left meter signal wire to the white speaker jack stud that's likewise screwed to the DCP. I used a ring terminal for a #4 stud or screw(4-40), and 22 AWG Teflon insulated wire, black heat shrink and a small piece of red for right channel, white for left. The ring terminal goes under the screw head and contacts the trace and screw for the respective channels jack. All we're doing is changing the location of the signal wires from before the DCP relay, to after the DCP relay.
Easy to do if you have the parts.
Congratulations on reviving your dead amp. Excellent!!!
changed both q5
left q8
left d8
fixed 2 broken wires...i think from handling...
couple of bad solder joints
one broken trace
this was over the whole event...
earlier changed 5 outputs left channel...
one driver transistor...
i am estatic!!!
this is a great forum....lots of guys that want to help!!!
lots of nice people...
i WILL pass it forward!!!
Glad you like that piece of Schiit btw. I still got two of em and I like em just fine for less than 200, a nice DAC. Hell, the Modius has balanced outputs as well and still 199.00 shit, I can't beat that.
Good lord Gene.
if you ever hear scratching and pops and clicks on power up....its gonna be a bad day...both the 400 and 200 started with that...and to be honest...i made mistakes that cost me also...
sniff and the gang are right...this old stuff is very difficult and fragile...one thing leads to another...
however...i have gained so much....
thanks!!!
changed both q5
left q8
left d8
one broken trace
i am estatic!!!
left d6...not d8
your schiit is fantastic!!!
nice dac...exactly what i needed!!!
THANK YOU!!!
Gene
Is that the 400 you just Fixed? In the pic, Way to go.
Oh I use a computer fans to cool mine. their cheap and all you need is 12vdc wall plug.
been using them for YEARS they really keep it cool and make it last for years.
Good work Gene
thanks!!!
Which one is this? do you have Variable Transformer?
could be the cap's are reforming, best to bring them up slowly
Gene
Good work Gene
yes sir, it is!!!!
you are very kind!!!
maria and i are enjoying bochelli !!!
it sounds wonderful...
this is a fearher in the hat of the forum!!!!
BOTH...400 and 200...thats how this adventure started....
the 400 is dead silent now!!! between selections!!!
i am waiting on a transistor to finish the 200...
joe sent me a couple in the kit!!!
my sx1080 and pl400 have both been refurbished...
200 is almost done!!! as well...i need the power supply caps...mouser has them....20 each...i will gift the 200 to my son in law ..
could not have pulled it off without phoenix!!!
4 fin or 8 fin using fans???
Gene
Does not Matter (can spaces the fans were you need them I put it behind the amp and blow into the Transistors
cuz I make my own.
I use DC computer fans w a 12vdc PS
Pic of simple one,
It has a cheap computer Fan control, 4- speed adjustment pots
and one of my home made one w 2 Fans . I have some base's made of wood and the power is a wall mount 12vdc PS
Pic #2 I just built a New one w temp displays and Fan Control
I love the Pioneer gear! I also have some SX-1050 ,, SX-XX50 and RG-2
Oh my electronic teacher was asked what kill Stereos , He paused,, and said Heat destroys everything
I than added fans to my Phase linear 400 II
Congratulations Gene, proves that persistence will be rewarded.
I might have asked before but what kind of speakers are those? They look really nice.
