- Mar 6, 2022
It is a varistor Gene, not really a cap. It is usually used for line surge suppression. Appears you had a surge.well, bought new battery charger...name brand ... used it b twice....today a puff of smoke....burnt cap plainly visible...
can anyone tell me what it is so i can replace it...photo included...it upened up like a taco
thank you so much!!!It is a varistor Gene, not really a cap. It is usually used for line surge suppression. Appears you had a surge.
SIOV metal oxide varistors, leaded varistors, StandarD series
wont work in my bedroom ...kinda etched in cement filled bloch...and no space for another box...for the 30 amp plug ...and cutting plug on milking machine would have voided warranty...lolololMaybe use 30 amp outlets for the 220 line so you can't plug the wrong plug in... --o| instead of |o|
Invest in a label machine to mark 220Vbottom plug is 220 for a/c..
top plug is 110. .for all gadgets in the night stand...including lamp...really didnt want to bust cement...
lololol...i get into trouble when people mess with my stuff!!!!Invest in a label machine to mark 220V![]()
lolololol....Forget the label maker. Rattle can of glow-in-the-dark paint!
when my new charger arrived i gifted my son with the old one...IT WAS WORKING!!!lolololol....
lololol...we turn it down at the first blood trickle from our ears!!!And with that much firepower, why are you playing anything at low volume?![]()
