phase linear 400
i bet my son plugged itbinto 220...they have equipment hrre that is 220 but uses standard 110 plug...my a/c window unit and milking machine are two that come to mind...i made a conversion cable with 110 and 220...using 110 looking outlse...220 is clearly marked...but easy to forget...the relay on the charger for turning it on/ off is dead as a doorknob...such is life...guess time to get another
Maybe use 30 amp outlets for the 220 line so you can't plug the wrong plug in... --o| instead of |o|
wont work in my bedroom ...kinda etched in cement filled bloch...and no space for another box...for the 30 amp plug ...and cutting plug on milking machine would have voided warranty...lololol
can someone offer an opinion...
my main system is composed of 4 hafler p230s monoblocked...with 3 wopled 400s...(yes i pulled the stock units...one is down...to be upgradedbatbavlater point in time...my plates pretty full....)...a 2x4 dsp, tuner, equalizer...dac...remote volume control..
should all of this be chassis grounded to each other...or is that a no no...i have 2 dimmable lamps that create noise into the system, noticable when played at low volume...
