- Mar 6, 2022
please post that s2 schematic...Oh, I see your point. Well, from what I see, it looks like it should work at 110 VAC.
Disconnect those old caps and test the power supply section for B+ and -.
If they had a long wire disconnected from the thermo switch, and a short wire disconnected from the main fuse holder, and those two wires were connected together, then I'd say it was wired 220 VAC based on the S2 wiring graphic.
But what's up with the white wire with what may be a stripe. Looks like one goes to the buss bar, so that's the center tap. Is the other connected to the back wall or buss bar?
The S2 dual primary transformers have a single black stranded center tap wire.
The S1 standard transformers have two solid enameled wire center tap wires.
If both of those white wires go to the buss bar, your good. And of course the other two white wires are AC for the meter bulbs.
Disconnect the caps, lift those rail wires up so they don't short, and test. Your probably good.
one wire out goes to one ac side of rectifier...
one wire out goes to other ac side of rectifier..
remaining wires out goes to busbar....between caps...i think windings can be configured parallel or series in output ...
i think input windings are the same...for series or parallel windings....
i think somebody tried rewiring and blew up a bunch of stuff...the wiring does not look like factory wiring ...why would ine wire be under a cap???
