- Mar 6, 2022
specs say it is true rmsiv
but, its broke...only used it one time to set the bias on the wopl...
yes sir...i do and have posted in other forums...Gene, do you know there are other Forums on this site? Testing, Speaker Building, lots of Discussion Groups.
You are not required to post everything on the Amps, PreAmps, and Receivers thread. We don't mind, of course. But you might attract a Fluke expert in the Testing Forum, for example. You have such talents and insights, it would be good to share them in some other threads.
For anything related to the PL400, this is certainly the right place.
We are the same guys on the other threads too Geneyes sir...i do and have posted in other forums...
i kinda trust the bunch here that have helped me so much...i should have called this thread ...my adventures with the 400s...i happen to notice this thread has nearly 70 000 views...i hope it helps others along with their adventures with the phase linear experiences as much as i have been helped...
i had no idea it would have been this addicting...
i try to play nice and follow protocol...
thanks to all...
maybe it would be nice to have both...a 77 4 or up along with a nice desk version...i used the cap checker on the kit from white oak to identify those little bitty blue caps i could not read with a headlight and two magnifying glasses....maria and i really enjoy our music...i have spent a bunch...lolSuggest a DER EE DE-5000 LCR meter for caps. What model of 77 do you have?
The 8050A does diode checks. Actually has 3 separate ranges for "turning on" silicon junctions.
Huge operators manual.
thanks for pointing out things to me...
maybe it was a recap kit...dont remember exactly...Little bitty caps??
you made me go look that up...Suggest a DER EE DE-5000 LCR meter for caps. What model of 77 do you have?
Not I Gene. All the components I use are senior friendly ?-)maybe it was a recap kit...dont remember exactly...
1/4 inch blue round electrolytics...non polar...
i could not read them all...used process of elimination and meter to figure them out...
you guys are pros...this is a hobby for me...
forgive my incompetance...
lololol....Not I Gene. All the components I use are senior friendly ?-)
The fuse kept blowing so I fixed it...
Defiantly do what Gorge said Inspect the Board , Very Good Links
