- Mar 6, 2022
what i learned today...
the dsp bluetooth module will stream but not let you configure from the app...parts express thinks its a bad dongle...have sent another...
the dsp has a 3 position switch on the back for turn on...remote control, mode speaker mode, and rca mode...it is very squirrely in the rca setting...some times it will not wake it up...sometimes it will just shut off for no apparent reason...in the remote mode it works perfectly...the auto on off stuff is by passed...when you apply power...it comes on and stays on...
dont know if it dont like my schiit...or if the bt module is not the problem...will know in time...
got most arranged and listening...
i got the new to me fluke down...only used it once to set bias on wopl when i changed out the transistors...it would not turn on...thought dead battery...nope...blown fuse...11 amp...smaller of the two...but is only fusing the two higher amp inputs...nothing to do with other functions...
sometimes it will power up...mostly no...
sure looks like it tangled with something that blew the fuse...and wounded...i disassembled the meter..nothing apparent...guess they got me...i did absolutely nothing with the 77 except the bias readings...the painter aint showed his face either...
voigts ready for paint...8" drivers here this week...really would like to try them out before paint...anyway...it will come out in the wash....
take care...suggestions??
