Are your +/-15V regulators close to 15V on each of the 4 test points. Don't slip your test probe. Bad stuff can happen
you know this is over my head...you are so kind....
this is totally not possible without phoenix forums...
lots of beautiful support...
HUH???
you are so kind....
Yes, I agree. Is this not a issue?the important value is the difference from "0.000" -0.0023 is still more than 0.001 from zero.
We will have to give Gene lessons in magnitude and sign for the next lesson I suppose...Hmmm,
row two installed...Oh, I see, he's already checked the regulators. Well, there's Joe's Rule #1, Check the test equipment. Later.
i try not to make the same mistake more than 2 or 3 times...lolI'm on the edge of my seat hoping he doesn't slip a probe.
make that + .8 mv....if that is true george....then we have just moved up from strict low middling.....
right into high cotton....
with all the back wall populated.....
no smoke, noise, sparks, flames, etc....
came up peacefully....
right channel offset - .7 mv
left channel offset + 8 mv
thanks mr. sniff...i appreciate the encouragement...Man you are going to go gray AND bald worrying about all that.... If there were issues, you'd know it.
