phase linear 400
Are your +/-15V regulators close to 15V on each of the 4 test points. Don't slip your test probe. Bad stuff can happen
Oh, I see, he's already checked the regulators. Well, there's Joe's Rule #1, Check the test equipment. Later.
row two installed...
.9 mv and .8 mv...
you said...less than 1 mv is good...
- 2.3 mv is less than 1 mv...
lol...
feeling better...
the more rows the closer they get...
Cool, it's looking better. Thing is, if I understand correctly, there is + and - VDC on those test points. I see this on my Flukes with the polarity symbols changing. The goal is to be in a window + or - .001 VDC on either side of 0 VDC. -.0023 is outside that window.
Joe, please correct me if my understanding is flawed.
if that is true george....then we have just moved up from strict low middling.....
right into high cotton....
with all the back wall populated.....
no smoke, noise, sparks, flames, etc....
came up peacefully....
right channel offset - .7 mv
left channel offset + 8 mv
make that + .8 mv....
as joe can attest....i have trouble with the decimal point...
that is less than 1 mv from zero on both channels....
i hope that is the way we understand it...
i wonder why the offset was high until the output installation sequence began...
now with all installed....is very stable...
hope that aint my wishful thinkin....
