Phase Linear 400 Repair
#41
I wish I had the eyes and patience to do this stuff. I really want to look into (pardon the pun) Lasik surgery
#42
Joe's got a pretty good eye for that stuff and has pointed out some electros I had put in backwards once...it can and does happen..
#43
Yes, that's what I did the BOM. Everything else in the picture seems exact but your explanation makes sense to me. When I'm all done I'm going to take some photos close up just to make sure you guys don't see anything wrong
I sent you an updated photo Brett. Follow the BOM and bag labels for all component references. Things change and the BOM listings and labels are always the most up to date.
Brettl
Pittsburgh, PA
OK this should be a done board, fingers crossed!!!!! The jumpers are not supposed to be on this one because of the back Plane:
( Important Note: When the PL400 or PL700 Backplane Board RevA or RevB is used, the 3 bus wire jumpers should NOT be installed on the back side of the PL14_20 board.)
#47
View attachment 20599 View attachment 20600
Correct, no jumpers when used with backplans. The backplanes provide +/- and grounding for each channel.
audiobob
Auburn, WA
Like a kid in a WOPL candy store.
#48
All else fails, follow the BOM. Joe may not have updated the assembly pics as fast as he updated the boards. At times he'll add components and spaces with some experimenting in mind as well as a later component change. We have played with a lot of different component changes over the years. Some worked out and some less than optimal results. Joe told me once that a SPICE model can predict performance but not how the amp will sound....he counts on the rest of us for that info...
Funny, its not uncommon for the tech manuals like parts and electicals to be a year behind the machine builds for CNC machinery.
audiobob
Auburn, WA
#49
I'm getting ready too Ron to look into the Lasik thing as its a bummer always having to put my reading glasses on during work or just reading.
audiobob
Auburn, WA
#50
Looking good Brett.
Brettl
Pittsburgh, PA
Finally, getting ready to pull the trigger on the back plane purchase. Question, How does the back plane build compare to the control board? Also is it pretty straight forward how the two connect to each other and other components?
Thanks, Brett
MarkWComer
Gaston, SC
#53
Thanks, Brett
I thought that building the backplanes was simpler than building the control board, less components. The only thing was the threaded standoffs and the large area copper traces- you will need a HOT iron for them.
Connections really aren't complicated at all- make sure you get the wiring kit, though, and be careful about how you allocate your wire lengths (I screwed up a bit). There's enough wire included to string everything up.
Don't forget- you will also need the transistors and silpads- order everything at the same time and avoid project pauses.
You have all the other crap, too- right? Variac, dim bulb circuit, and the fuckin' Heyco pliers?
You have my number- give a call if you get stuck- I'll try my best to help!
MarkWComer
Gaston, SC
#55
You will need to reroute your AC line in from the strain relief (where it enters the cabinet) to the thermal cutoff at the center point between the backplanes. To do this you will need to remove the strain relief (called a Heyco strain relief) with a specialized tool.
...or you can splice an additional length of wire.
Brettl
Pittsburgh, PA
I was going to add a new power cord as the old one is crappy!
R1200S
Foot of Mt. Belzoni
Smoke and mirrors baby!
#59
Mark and Joe, do those look like they'd do the job? I know they're generally expensive but that's a good price. I'd take a gamble on a pair myself if you guys think they'd work.
