I am sending Joe one of my 2000's so he can peruse the situation up close and personal....that's what he meant by being patient. It will be headed his way Monday..
You guys are so nice
Do these things have a "death cap" that ties one side of the power line to chassis for a pseudo-ground reference? I wonder if that might be causing hum if that is the same place the RCA jacks ground to. I dont know if they were still doing that stuff by the 70s, but it was very common in the tube era.
Well,
I replaced all the caps by the original values, threw in the new transistor, checked the continuity of all the tracks, made sure that the bolts to the chassis were tighten.
I scoped the equipement and it appears that :
The 50Hz hum is still here (as light as it it is...)
REAR OUTPUT doesn't work (it wasn't working before).
FRONT OUTPUT works well for both hi and low level inputs
Strange thing : the preamp sends a 50Hz signal to the output when it's off. I noticed it when I heard a sound through my speakers while it was off. I scoped it and it is a 50Hz signal....
Well,
Take R68 (33K) and C39 (0.0027uF) off the AC power switch and see if that gets rid of it. It has in the past.
Did you install sockets?
The ones I sent I pulled from an old one I had laying around. I thought I had some spares but they turned out to be 4136's. I do have some more I could pull if need be....
Yes Please!The 4739's are a very weird duck. I have tried quite a few in it's place and they always oscillate. Joe tells me it has something to do with bandwidth and phase angles. We were going to rework the circuit on a 2000 to accept a different op-amp one of these days but so far have not done it...
Understandable, I will definitely be interested in seeing how this progresses.Life is pretty tough in the oilfield right now and haven't had the time....someday...
What happened with the NOS 4739's? are the issues solved?It's very kind of you Lee, but, as you know, I found a NOS here, I think I'll go for new ones.
I hope this preamp deserves all this sweat![]()
While reading about the op amps, I read that improving the power supply would do a lot to improve sound. What are your thoughts on this? What would one use as an upgraded power supply?Life is pretty tough in the oilfield right now and haven't had the time....someday...
