- Jan 14, 2011
- Gillette, Wyo.
Well, I replaced Q2, and I have no more Buzz but a light hum is still hearable ...
60hz hum?
60hz hum?
60hz hum?
Yes it's a 50Hz thing. Can't figure why :/
One simple check is to verify that all components are plugged into the same AC circuit. It is possible that differences in AC potential can develop between grounds of different circuits resulting in a current differential between the grounds. This can cause voltage drops across the ground wires in the power cords of the circuits that provide power to the audio components and this has the potential to create the line frequency hum.
I don't have a ground wire nav
An other consideration, I noticed that I had to use quite high resistors values to lower the LED brightness (about 300k), can this affect the functioning of the TIS97?
The TIS97 in that circuit is just a poor man's zener diode. Why PL did that I will never know.
The high value is right, the LED you have is an ultrabright and you do not want an ultrabright in that application.
They don't have neutral wires over there either. 220v, both are hot.
I suppose there is a possibility of inverted phase on the power wiring though. Not sure if the cords can be flipped over, but that might be worth a try.
It's troubling indeed....
Well, I finally checked the values of the new caps that have been replaced by the previous owner, I can't figure out why but C42 and C43 where downsized from 10/50 to 1/100 (???) and C47-48-49-50 where also downsized from 22/35 to 2.2/50.
I suppose it is worth to change again these caps and that it could help with the hum thing... right?
Likely will not fix your hum but it will improve your low end frequency response. The P.O. did not do the right thing by this preamp. What did the P.O. do to the values of C40 and 41?
My suspicion is that there is a ground loop inside the PL2000 because of the multiple DC ground tie points to the chassis. Never a good thing.
And maybe many others....
Perhaps can I install some jumpers to the DC ground?
We will see what we can do to recommend some improvements. Be patient though...
