- Jan 14, 2011
- Gillette, Wyo.
A few wiring questions:
This is a 400 Series II- LED output meters. There's a red wire and a black wire coming from the meter driver boards- I deduce these are the meter inputs. These connect to OUT1 of their respective L/R backplane boards. There is also a white wire- assumption sez that this connects to the stud ground- correct?
The WA DC board uses an AC connection from a stud on the rectifier- route it above or below the backplane boards? DC connection will be via FUSED_B+_OUT on the R backplane, ground goes to the stud ground in the center of the L backplane.
Speaker outputs (OUT2- yellow wires at the top of the boards) route atop the backplane boards- should I route the speaker grounds coming from the copper strap above or below the backplanes? I know there's an issue here regarding inductance from AC wire proximity (the thermal switch) affecting noise in the amp.
Just wanted to clarify before I burned the house down...
The DC protect AC line should be routed on top. Ground from the DC protect goes to bus bar. The speaker positives should go straight to the Protect board from where they are. The speaker grounds should go down around the bottom.
