Larry's Phase Linear 700B
SHIT"S FLYIN EVERYWHERE!!!!!!!!!!!!!!!!!!
Well , I've taken the Larrt WOPL to at least Mach 8 with the SP-12, Larrt I think you'll be tickled with both pieces, god knows I am!!!!!!!!
I like it too Lee. It was always pretty dicey getting your measurement probes in behind the board to make the bias measuremet without accidentally touching the wrong thing. It made the board a little wider to get that trace in there without going near any sensitive circuitry but I think it was worth it.
ABSOLUTELY LOVE IT JOE!!
Welcome Larrt. New outputs and drivers going in now.
Changed out the outputs and drivers and the meter. Now putting it on the AP and doing the final performance checks.
BTW----THIS AMP IS FOR SALE AND COMES WITH THE GUARANTEE IF IT BREAKS SEND IT BACK, I"LL FIX IT< FOR NOTHING. YOU PAY SHIPPING ONE WAY. That's it, no questions asked----unless it's been picked up in a tornado and hurled for 100 miles.
Frteq Response.... Normal coupling
Maximum power output just before clipping....into 8 ohms , both loaded and driven
Changed out the Zoebel network and also relocated it to the DC protect board. It was between the outputs acrosss the 3 terminal strips, hate that. I think it's awfully cute where I put it.
Larrty, a couple days of torturing the neighbors then off it goes.
Finally got the 2000 watt load cell above lukewarm
Check out the left meter. Bad solder joint on the light board. your meter was fine.
Shakin the F(*&^%$ walls NOW!!!
That other thing in the pic is learning some lessons from it's older sibling on the correct way to reward your creator. And it's gonna stay attached at the hip UNTIL IT LEARNS!!!!!!!!!!! Big Brother is blasting tunes to the neighborhood again. Been awhile since I had this much clean power----GOD I LOVE IT!!!!!!!!!!!!!
Yesy Larrt, I'm very happy.
SHIOT!!!! Vibrating eyeballs again!!!!!!!!!!!!!
