pennysdad
- Feb 27, 2013
- In witness protection.
- I've totally lost the plot....
off to bed.... L8r all.
I'll hold ya to it, Lee!If you're ever in Wyoming stop by, I'll make you forget all about the DQ's....
And...if you're in the Michigan area you come on by and I'll show you what high fidelity is all about!![]()
I gotta give ya that one, buddy!I think that would be called semi-hi fidelty till those WOPL's are FC'd....
The difference you hear between a WOPL and stock, that is almost as much difference you hear between quasi and FC. More soundstage, tighter controlled bass.....
Jason, that's really a cool offer...ya know it's 215 miles from Mill Creek to Swartz Creek one way...3 hrs 12 minutes to be exactHey Dave if ya ever want to hear Jessica Lmk I'll make the drive. And you could hear her on your setup.
So I decide to get busy refinishing these speakers as I really want them in the man cave, instead of the bedroom. I armaflexed the drivers and the speaker terminal cup. Tightened down the nuts to the rebuilt tweeters. Yuo they were loose, surprised they did not short out or blow out as they were rattleing loose. I also stripped that ugly ass black finish as well spent the whole day sanding these things down. I am going to leave the wood as is. No Stain, but a sealer will be applied to them. The risers will have to be remade as I did manage to burn thru on the bases, trying to get the paint off of them.
Any who on with the picks
These speakers are bad ass. Better than my SDA2's that I molded as well.
Need to do some more sanding work though, but my back wont stand for it today so some other time
Anyway back in the bedroom they go
Crap, what happened to the nice Black finish?![]()
My sander was hungry for some black paint
I generally like black speakers, but if poorly done then wood grain is far superior. I have a set of bookshelf Wharfdales that I covered with woodgrain shelf paper cause I thought the black looked cheap. They don't look too bad for shelf paper and since the front and back of the cabinets are plastic and totally come off I simply wrapped the shelf paper around the box, glued the ends inside the cabinet and put the plastic fronts and backs back on.
I've had a guy sit in the masters chair that owned a pair of DQ 10's and he told me don't waste my time, these K's put em to shame....just sayin.....
That's cool...You love your system and I love mine...we're both happy and that's what it's all about, after all. I am going to have to go full complimentary this winter though. I've blown my budget for the summer, so that has to wait.I've had a guy sit in the masters chair that owned a pair of DQ 10's and he told me don't waste my time, these K's put em to shame....just sayin.....
