Gepetto said:I will run the relay cut out test case through the SPICE model that I have built for the Phase Linear amp and advise if it discloses much.....Regardless, once clip is hit, the final small imbalances between the plus and minus rail will be seen at the output and trip the relay circuit as well.
Clear as mud guys??
I suspected that somehow there was some asymetry,but couldn't explain it. I was thinking feedback loops or frequency response, but wasn't about to speak without supporting test data. This makes a lot of sense.
My test set for the 700 board uses a variable +/- DC supply to insert an offset voltage. The trip point is about +/- 8VDC. The power supply is unregulated and has about 150mv of ripple.
