Johnny D's 700 Adventure
Re: Phase Linear 400
Welcome John, good luck with the project.
Hi laatsch55 and Gepetto,
So far changed the transistor plane resistors, IN4004 diodes, and the r/c input network and switch..testing all those old resistors they were so far out of each other. So now i have Joes board and the dc protect board in, just awaiting the PS caps..
How do I attach a photo?
Open the full editor button at the bottom of the edit window, that will expose an "upload attachment" option. Use the Browse button to find your picture file, attach it and click the "Add the file" button to the right of the File Comment window.
Quite easy.
here is the finished boards..
Hi John
Do you have any AC wiring in that harness that is running around the board? I cannot tell from the photo.
If so I recommend segregating all AC wiring in a separate bundle and keeping it well away from the DC and signal wiring in order to obtain the best noise reduction results.
I also recommend keeping the low level input wiring away from everything else.
Joe
Joe
joe its the black and white wire thats braided at the bottom of the bundle of the wires..
joe looked around amp, very hard to keep away from signal, board or dc wires.
Only other way is to bring it outside amp, shield cable seem to be the only logical way to get it to dc board..
Recommend using a shielded twisted pair to get it there then John.
ok let me see if I have some pair shield cable. think 20ga be ok?
If it is just for the DC protect, yes that is fine.
Joe, did you spec different caps for C1, C7??
No Lee
120pF CDE Mica 5%, selected to match. That is what I have been using all along. Why do you ask?
Joe
Doesn't look the same on John's board.
That is what the stock I have looks like Lee, the classic shiny maroon colored CDE coating, whatever that stuff is.
joe/lee
question where should the shield ground to, the chassis or the ground buss on the PS caps?
If you are running a shielded for the DC protect board---nowhere.
Joe, looked at the shielded wire I have and its 24 gauge, do you think I should get something heavier for the dc protect board?
Also is there anywhere in the forum that talks about Altec Lansing amps? Have 4 1590e 200w professional amps that are very distorted when playing. The have transistors feeding a output transformer.
I'd perfer a Mac, but little outta my price range....what you think about the wire size Lee..
