Johnny D's 700 Adventure
Re: Phase Linear 400
Did you complete the re-grounding??
I think I am going to have to get around to doing a diagram on the grounding Lee and John. Time, such a precious commodity.
yes jump 5r and 5L and soldered to buss connecting PS caps and cut the link between the output and input ground...use the volume controls on from of amp, both playing get distortion, turn off left or right channel and distortion goes away..crosstalking some where.
And as i get older it's going from precious to priceless.
Hmmmmmm...........................
that's laatsch55 for I'm thinkin.....
Are the shields on input to board terminated at both ends?
The amp plays excellent but certian frequencies buzz thru the tweeters...trust me its not the speakers...especially piano and guitars. sounds like a leaky transistor or failing cap.
Didn't think it was the speaks. We're still not out of the woods on this grounding thing. Are the shields terminated at both ends?
gonna rip the back plane off and remove all the junk not needed and wire inputs direct and have 2 grounds, one for inputs and one for speakers soldered to buss.
gonna go, need a break....pick up on it tomorrow...thxs for the help and tid bits about the grounding. Thxs again laatsch55
Yep and run separate grounds for each speaker output negative. I know it sounds redundant but there's a good reason for it, but at this moment in time I can't remember, a crown and coke and Patricia Barber in the background.........
Johnny D. Please read this---http://forums.phxaudiotape.com/joe-s-improved-grounding-scheme-t2544.html
I will read tomorrow, thx for everything. hear angela walking around must be time for bed.
Good nite, talk to you tomorrow..
How you today?
I removed the binding posts all the wires and rc components and the switch...nice and clean now.
Notice a wire hidden in the back, white w/brown trace that grounds to chassis, connected to ground post of standoffs for the emitter resistor banks. hidden ground I didnt see behind all the r/c crap.
What to change out emitter resistors, what kind are not noisy, metal film or wirewound?
Read the grounding scheme from joes article very educational.
Also where can I get new PS caps without spending over 100 dollars for 2?
I posted a link tyo Apex jr. 22,000 at 100 volt for 23.95. Build date of b2001, but i'm running a lot of them. They are shown as Adcoms, but are really built by Cornell-Dubilier.
Metal film of the 1% variety is a good choice.
The middle tab of the 3 terminal strips between rows of resistors were Phase's place to chassis ground. they seem fairly benign where they are.
And to your first question--Very Good. Only had to work 10 hours today. Short day.
So the problem is fixed??
Page 2 of this thread is the Apex link.
Johnny D. I might add those caps fit the 700 "B"'s LIKE A GLOVE.
