Jer's 400, number TWO thread...
#22
Ah, I color coded mine this time. That silver wire is sooooooooooooo well behaved.
#28
Exactly Nav!! Damn it's good stuff, and the selection you sent is exquisite!!
NavLinear
#29
I've been lucky as I've been using this type of stranded wire for many years. It was way expensive several decades ago but now it's more affordable now. I need to get you some twisted shielded pair wire - you'll like that also. I'll send that with the Spec 2 when that all comes together. I'll get some single conductor shielded wire for you to try out.
#30
That would be excellent..... about time to post ih your thread again isn't it???
NavLinear
#31
It's getting closer - completing the last of our flight hardware and I don't like tearing down the test bench while fabricating and testing so...
jbeckva
Admin/Server Dude MAA Guy
WassupYa Mang?
#34
Got the DCP put together tonight. Well ALMOST.. I done-dood it again and forgot to order the phoenix connectors.. :tool:
Good nuff for tonight. Beat .. bushwhacked... "work" is killin' me... :banghead:
jbeckva
WassupYa Mang?
#36
Ok, so here's one of those decisions... I believe I have enough to at least make some sound with this guy. Now look below - see the two wirewounds in place of the normal .22 ohm resistors? I can't hang with that.. bad idear to be having them in there, right? What I am proposing is to go ahead and replace those with some leftover MOS .22's I have (see my previous 400 thread.. they are the grey/tan colored ones). For NOW.. I'll leave the rest as the old carbon types. Any risk there, folks? D board and DCP all built and ready to go in, too..
jbeckva
WassupYa Mang?
#37
And then.. I pulled the covers on the back.. what a mishmash.. I have 410's for the right drivers, SK3560's on the left. 4 pl909's of one datecode + 2 pl909's of another on the right. and 6 sylvania ecg87's on the left. Well, that'll be "fixed" soon..
#38
No risk with the old MO emitter resistors. No problem with mixing date codes.
jbeckva
WassupYa Mang?
#39
count em Lee.. FOUR different models between the drivers and outputs, both channels. MJ's are going in, plus I'll see about those 410's I had yanked from the 700 when I was getting some oscillations - mebbe that was a socket problem, not really sure... :confused3::toothy10:
#40
So you have some extra 410"s?? The ECG's are a big worry. Glad you didn't fire it...
