And a coupla weeks later.... as the "Shpongle Turns", so to speak...
I'm still looking at these two huge frickin caps, thinking..   And I think I'm just gonna "trailer-neck" it (that's a cross between trailer and redneck, btw.. neat term eh?).   I'm gonna strap 'em to the back and run heavy gauge wire into the PS circuit board.
So that's leaving the 2 33's for the "big ones".  Now.. I'm wondering about those right now.  They're the same physical size (about 63 x 63mm or so).   And what's important there is that all four (originally) were the support for the PS circuit board i.e. the board is soldered to all four, which in turn are clamped down with a 4 position cap clamp bolted to the back plate.
Soo.. I could go a coupla ways there..
First are these caps that are as close as I can find.. 50mm x 50mm.   That would mean I'd need to put some spacers on the caps to still have the clamp hold them.  I'm figuring that if I had at least 2 of the 4 caps still in place, that should provide enough support for the PS board.
Or, the other idea..   If I can find some 33K's that are also computer grade BUT I could stand up on end on the inside (won't be any room on the outside after the two big bammer-jammer 48K's get strapped on).   That leaves the PS board to worry about, but why not just stand it off from the back?   I'd need 4 stand off rods (or whatever they're called) about 65mm long.  Then mount the PCB on one end and secure them on the other through the back plate.
Soo picture the back end for a min... (here's an earlier photo here.. )
The caps and clamp go away.   Then the PCB is stood off the same distance as if the caps were still there, which should leave enough room to mount the 2 33's vertically.  And again just like the 48's outside, the 33's too would have heavy-duty jumpers to the original mounting holes on the PS board.
Hmmmm... might just happen next week, methinkin...   I hope to "Shpongle" a few things off walls when it's all done...
