- Jan 14, 2011
- Gillette, Wyo.
BABB.............
I have relocated the bias transistor brackets more to the middle of the row, located and drilled the hole for the top board mount, this 400C had a 3 bolt holddown pattern in a V. BR wired and soldered, most of the Star ground wires prepped and terminaled, wiring rebundled so most hi volt DC over the top, low volt DC on the bottom and the AC through the middle. May be testing late tyonight.
More.....
Well Joe, space is kinda tight for the 5 watters so in the 400's we're going with 3 watters. The Poly cap takes some imaginitive lead bending to land it ,but it works. I'm happy with the wiring rebundle on this one, we'll see if it translates to lower noise.
Sometimes the Lord is smiling down on ya. .002-.005 clearance between the relay and the meter bezel, Jeez.....
New silver hookup nwire in, new shielded signal ins, And silver jumpers on the back if the board.
