Handles for 700's
You want to give our amps hand jobs?
almost there................................ Sorry, can't blow it up bigger. Dude had a hell of a time. Seems that the original handles were not concentric and a 3D scan would have been pointless. So, it's a whole new hand-Job.....
CAD Drawing.
Must be something about having your hands in their guts for DAYS......
400 owners, start measuring center hole to center hole for handles. If there is not a big need for 3.75" handles, it will be cost prohibitive to manufacture them. If I don't get feedback, I'll skip them altogether.
I measured the 700B face plates, and the Clair 700 II's and the hole spacing is 3.875" center to center. The handles are wide enough to drill 3.75" (.06" in on each side). They should do it.
They should look like the originals except just a hair wider at the base for drilling for different widths for the 400/700B/Clair. He's printing the model for the mold tonight.
Nothing wrong wit that, make it bigger and better....
I have four 400 series I and center to center is 3.75 inches. Depending on pricing I'd take up to 8 of them. Bolt threads are 1/4-20.
I think I have 7 or 8, and feel the same way as Fred.
Good work!!!
I just measured an 8 fin 400 and (2) 4 fin 400's and they all measured the same
Center to center appears to be 96.5mm or about 3 13/16" on all 3 of them.
Also PL2000 s1, appears to be 3.5" center to center
Well, that's a pretty good response. We added material around the base so maybe we'll get lucky and be able to drill for 3.75", if not, I'll have him shorten the handle by 1/10th" and go with 2 sizes.
