- Jan 14, 2011
- Gillette, Wyo.
Lowest bias setting of 432mv, offset was .001mv, highest bias setting of 732mv, offset was .002mv
Inputs hooked to the AP with the AP off.
I use all 75 ohm cables Lee, RG59/U
Yes Joe, this is the right channel. Behaving as it should?? Did you see the THD & N figures for this channel??
With no inputs or outputs plugged in offset goes to 12mv.
Naturally.....
Negative 12mV? It should be negative (NPN input stage). I typically see -0.010V
RG59/U is very common for BNC connected cables.
