ESS AMT 1C
#22
I have extra chassis, transformers and stuff. Skratch is running some one-hole-in-the-middle faceplates so it's not a problem to do...we can cascade a complete set of backplanes for single channel use...wanna do one anyway...
Nick Danger
#23
I am more than onboard for some mono blocks, Lee. Are you still trying to put some things together for RMAF this October?
#24
Yes, won't be able to get yours done by then though, I'll be lucky to get the monsters done...
Nick Danger
#27
ESS Tempest now up for consideration
Found out another local seller has a pair of ESS Tempest that need refoam but are cheap. Whatcha think?
#29
Shoulda had the info of the local auction to you that day but then again the woofers had lost too much foam and I simply could not try out consigned items like that. I missed out on the Sony STR-7800SD, the Sony turntable needing a fix I probably couldn't afford and the TC-K4A cassette as well but I got the cassette deck at a local shop later for $10.
The guy that won the Tempest Classics that night knew what he was getting.
#32
If I wasn't awash in speakers I would go for the Tempest though.
