- Jan 14, 2011
- Gillette, Wyo.
Yep. Sometimes it works, and then sometimes it works...
Wow, sounds like its going to get me evictedI should be able to fit it in here somewhere. Will remove some components to make it fit.
it won't fit unless you have them set fairly forward.
standard home entertainment units etc are 17" (or less) wide, and a pl with ears is 19"
plus those home units won't handle that sort of weight and will bow.... and possibly collapse, especially if it's an Ikea type of construction.
If for some reason we can't run the pair of stacked 400's I finished stripping the original 700 chassis. Jani will bead blast and paint the bugger.That's as far down as yu can take one. D2, if we go this way It'll still have separate power supplies and be fully comp. Just a little more work is all. Either way she's gonna be spiffy and an earthshaker....
Well yeah!! I'm interested.
This is bizarre, I was just looking at the mule this morning and was about to e-mail you about that very same thing. My hangup was what happens to the driver on the upper board.
OK, that was the last tidbit I needed. I was going to reverse the top board to have both tops looking at each other, the jumpers needing to be no longer than 3.5-4 inches.
Yep, just layed it out with some 700 Ser I heatsinks . The upper driver is the only one that lines up that way.
