You don't need to tip cows...they work for food.
Australia
That amp would have had a very hard life on the road until it met its final fate with the truck rollover.
All new Buddy....this was a fully comp amp too....are you going to want to run fans off the aux plug? Or do you have 240 volt fans?
Australia
To Make it easy for you, I will run the fans off an independent power supply. I'm thinking 14 blade dynamic fluid bearing aerocool fans. They push a lot of air and light up nice.
OK, good. That'll make it easier for you to wire up the transformer also...could you post a pic of the transformer here?? Where we can see the wiring?
Australia
Excellent pics on the transformer....Nice fans!!
Not much lleft...
Thanks Lee, that's only a basic fan, sucks the hot air up and out of the amp, the 9500s runs too hot to not be fan cooled, that's why it has lasted. But I will be getting some more 14 blade fans for the WOPL, they are $25 a piece.
