Next time, shine it on the black part of the transistor..
Ok....let's check low voltage test points on both channels. Negative to backplane ground, positive to test points..
Low voltage on the driver board, +15, -15 middle of the board and left edge..
DC offset, both channels...Neg to backplane ground, pos to backplane out...
Ok, now lets check driver board input voltages and compare right to left...Negative to backplane ground, positive to 3 thru 8 on each side, write down the values..
No....ccheck em all except input from RCA jacks and the last 3 on the left side of each connector block....those are ground and plus and minus.....well fuck, check those too..
