- Jan 14, 2011
- Gillette, Wyo.
After being on awhile minus 15 and plus 25..
One of the two transistors?I have 16 v ac coming off of each secondary prior to rectification. That is center tap to to secondaries. On the other side of the 1N4004' s is where the problem is. I don't t know where the additional voltage is coming from. All IC's are pulled. B+, B- voltages referenced from board ground.
If you subbed a TIS97 for the GES97 the pin out is reversed.One of the two transistors?
Put the old ones back in.1N4004 diodes are cheap...
And you know I have a bin FULL of em. How does a bad diode in a rectifier cause a doubling of the plus voltage?1N4004 diodes are cheap...
Bad cap? Saw you subbed some
Mismarked maybe. This has to be something simple. Your sure the wiring is correct including those wires that solder flat onto solder pads. None of those short switch wires are crossed. Does voltage become normal when switch position changes. Can't more help, on the road working. You guys know far more than me any how.I have lots of new ones George! No need to put old ones back in..
O.k.It is oriented correctly for the TIS97 Sir George..
