- Jan 14, 2011
- Gillette, Wyo.
If Joe's grounding scheme is followed to the letter, you no longer need a jumper to the faceplate....
TR-64. Or any 20,22, 24 gauge with teflon insulation.
Jer, if you can get the teflon insulated yeah, it's so neat to solder with, no burnback. Any good, reputable multi strand 105 degree wire is good.
Remove the meters before any random body work......
Jer, I have that teflon stuff from 16- 24.
Well figure what it would take to rerun the entire rail voltages, the main through the two thermal cutout switches, the control wires and some extra for incidentals.. That and the heavy duty buss bar for the star ground. That'd about cover it, do you think?
Will 18 work for the control wires tho? Too thick for the pads, perhaps?
20 AWG worked for me - if the board is pulled from the mounting standoffs and you want to fold it back the 18 gauge could be a bit stiff and I'm not sure if the through holes could that gauge.
