- Jan 14, 2011
- Gillette, Wyo.
Lyles 700 will not have volume pots...
I think you misunderstood me a little. I went into my mod work with my 700's already ripping the switch out because I'm going to keep it in DC mode and any superfluous (again, only to me alone knowing what I am going to do with it) circuitry like the switch would be bypassed - my own "purist" approach on a unit that was mine to work on and I listen to daily. The switch was gone even before completing the build and testing it. I had hum and ground issues even with it out of the circuit, for which both grounding analysis AND taking into account the level controls (again, make sure they are NOT wired with the wiper adjusting the input side) was how it was overcome. Now the "3rd extreme" is to bypass the level controls altogether, but even I haven't been quite sold on that concept.. but that to me is also an option - to discuss and not assume, if you catch my drift.
If I was working on a unit from another owner, and they specified the switch to stay in and function as it should, well there wouldn't be any argument past one quick "Are you sure?" question, explaining the pro's and con's. After all, it's not my amp to make that decision.![]()
"And NO mods to the pots, -20db switch or normal/coupled switch. I want the amp to function as intended"
Better De-White Oak it then, that's like being " a little pregnant"
or a
. Whichever you prefer..........Built any of these yet Dave???
Don't need whisper quiet fans when ya need fans.......................
Dave, do you have the RCA-410's as drivers??
They take an hour to build is all and they "Snap On". Got some green ground clips that sit and snap on the top then bring the bottom in and it snaps onto the backside of the heatsinks. We phanatics were brainstorming one weekend and these are what we came up with. Some 1' by 1/16 aluminum angle, and some 3/4 of same and they fall together. To get 2 to fit the back of a 700 it takes 2-4-5/8 fans.
No problem on the misunderstandings, hard to interpret finger tone and lilt....
)Ok, sounds like it's a "go" folks! Good deal. Dave you have my addy, right?
(coming up for air here before I finally get to get some damn sleep.. work is a beeeeotch...)
Gnight!
