- Jan 14, 2011
- Gillette, Wyo.
Coming frm a fabricator of your caliber that is high praise indeed!! Thanks Dennis. The outputs were obsoleted 25 years ago. They are also the outputs for one of the biggest, bad ass receivers ever made, the mighty Pioneer SX 1980--270 WPC RMS into 8. Conservative watts tpoo. I suspect at least 360 before it clips. Have never had one on the bench. These outputs were run at the behest of Pioneer during the time Pioneer owned Phase.
I have run into a snag. On bringing it up on the DBT, the relay starts chattering at about 60 volts. If this amp did not have unobtanium outputs I would just throw 120 full on at it as I believe I've reached the point where the coil will actuate but upon doing so drops the voltage enough to drop it out with the DBT doing as it should--limiting current. I have bypassed the relay coil and things are fine. So I guess I should nut up and give er the groceries.
