Comparing battery-powered phono pre-amps, from RS ($$) to ASR ($$$$) ... and beyond!
Thank you Sir, what are the quality of the capacitors like?
With my limited knowledge, I don't fully understand what he has done with all the component changes, but there has to be a reason for them.
I’m pretty sure you can too. Wyn indicated his preamp could be run off a pair of 9V batteries and it uses a +/- power supply.
That would be handy, after about 15 hours of solid use on a stock unit. the battery went from 9.5v to 9.2v. Im curious as to what the battery life is on a standard duracell alkaline battery.
I got four nice rechargeable D cells from China a while back.
The Sony D5M uses two, and regular cells don’t last too long. These last at least as long; probably longer, and have a mini YSB plug in them with an LED, so no fancy charger needed. Not expensive. eBay of course.
It started with D adapters that take three AA batteries each, since I’m already using those everywhere. But the single D has higher mwH than any three rechargeable AAs combined.
The D5 steps up from 3V to 6V so voltage isn’t an issue.
