Comparing battery-powered phono pre-amps, from RS ($$) to ASR ($$$$) ... and beyond!
Hi 3D, parts are on order, using 470uf cap for storage. Its good to know that the 1000uf is still manageable. You will have a powerbank with that many caps.
All resistors and caps are being replaced with the tightest tolerance possible along with replacement transistors. Only exception is the 2x 50v/1uf capacitors which will be 5% and there was a pair of resistors that I could only get 2%, all the rest will be 1%. The remaining electrolytics will be 20% audio grade nichicons.
Its great how far you plan to take the experiments and testing. I heard a slight difference between the two audio files using akg reference headphones. Maybe even more difference will be observed with the higher quality parts. I will also test with 2 individual upgraded units, 1 channel per preamp.
Got it, yes. Did about 10 hours work on it. Had to bypass a few tracks due to losing the solder pad. There were challenges due to capacitor size, managed to squeeze them in. The nichicon muse caps would not fit into the connector holes, the legs on them were too thick. I resorted to putting in separate legs and mounting the caps horizontally, not ideal and looks messy but it works, and thats all that matters.
Those BC237B replacement transistors have the wrong pinout, fuck! Had to put the C1740’s back in.
First test run the left channel was dead, tested Q1 which had an abnormally high value, took it out and tested out of circuit, no issues. Found C5 and C6 almost shorting, trimmed the legs to fix. Put Q1 back in, tested ok. tested for continuity and shorts all over the board. Now Im listening and it sounds sweet. Will record that same track used last time for comparison and share soon. No pics of soldering side of board, its a war zone :evil4:
Rca input/output replaced with gold plated type.
Cap/Resistor make and type used:
Koa Speer Resistors mostly 1%
Wima MKP, FKP 2.5%
Cornell Dubilier CDE Grey Film (For the 50v/1uf 5% Cap, couldnt find Wimas in this value)
Elna Silmic 2’s (Electrolytic)
Nichicon UES and UKZ (Electrolytic)
Stocked up on 50v/1uf Nichicon Muse BP green caps, just for shits and giggles, these come in handy, forever running out of them.
By the way, used sil pads are handy to protect the board from the jaw clamps.
ACBF7DC4-2718-4164-9BD1-A9352FA87A8F.jpegF5A4B3F2-DECF-42DC-9673-CA82845CCFE4.jpegFB85D6F4-E877-4E6A-B8A5-A4321D8123EA.jpegD294246C-8F55-4E3F-BE0E-6FB2B3DB167F.jpeg
Could not get the Audio DiffMaker program to work on windows 10, it asks for soundcard to be selected, click ok then the app terminates. Might try it on the windows 7 laptop to see if that will help. Time for rest, back on late shift tomorrow. It has been a productive day.
Write your 2 transistor pin outs down on paper. Bend the leads on the new ones to match the old.
When using a pin vise to enlarge holes, always start on the copper side. Use very gentle pressure as a copper burr is usually created. Reverse direction a little, cock the bit so the sharp flute cuts the burr off, continue. Don't twist the pad off the board due to the burr! Small bits are available in equally small indexes.
Muse caps are usually physically larger than Fine Gold "FG" counterparts.
Have fun, I enjoy watching your experimentation!
The Israelis have written their own avionics and engine management packages for their F100-229 powered birds (much frustration from P&W on this when engines are not performing properly).
The condition of their blades when we get them indicates they run them "at eleven"...
Here's hoping that someday you can break some windows with your own hot-rodded equipment. :0)
Keep up the good work!
3D
I have the amp, just need the speakers, 15 inch ones. Im super happy with the Jamos though. They go loud enough, and the neighbour’s house on one side is maybe 7 feet away. Glad I got acoustic insulation put in the lounge room walls, just need to do the windows next, thats where the majority of sound escapes.
