- Jan 14, 2011
- Gillette, Wyo.
Thanks for the moola Larrt. You just bought me an amp today I won on e-bay.
soundude said:Larry the wing c tubes are probably the best your going to get they still follow the stringet testing of the tubes when they leave the factory. When Eric Barbour was the engineer for them he put together a system for rating them and the factory still follows them. Eric is a very knowledgable gentlemen in this area, I still email him for tips and tricks with tubes.
I have use a excellent setup for balancing tubes in the amps with a fixed bias...its fullproof and you never have to mess with the bias. Its a 25 ohm 3watt pot off the cathodes and the wiper is grounded. each side of the pot has a test point connected to it and you set your meter for mvdv. with the probes in the test points you turn the pot till the meter reads 0.000 and the tubes are perfectly equal that simple. If you going to do carys its a mod, but I don't think you want to mess with them. its a great setup for mismatched tubes...great for when modding or add during a rebuild. I'll draw a schematic so you can see how it works.
speakerman1 said:Cary did my mod to bias my tubes. I would not send my amps back to Cary. Have had some problems and they talk to you like you are stupid. All the tubes are matched in them right now. On one amp I could not turn my bias to 0. To bias them. Now I have a LED out. Not happy at all.
Larry
Rex Everything said:
The 1st month or so I check a lot. Till they stabilize. After that I bias about once a month.soundude said:I hear ya, but keep a check on them if the tubes are new, they tend to drift about 20 hours in.
Always look at the plates in the dark near the seams if there is a dull redness you need to increase the bias more negative...
speakerman1 said:Rex Everything said:
Shipping will be 3000.00. LOL
Larry
