- Jan 14, 2011
- Gillette, Wyo.
They coul;d be....
no wonder..... it's got tea-candles in it!
wot? oh! they're caps that someone marked with a red pen. had me fooled there for a minute.![]()
That's Hilarious, I took another look at the photo and it does give an optical illusion of tea-candles. Both units have those markings on the caps, must be a factory thing. I shall be hooking the 2nd unit up to some speakers tomorrow to test, and if it works will integrate it on top of the cabinet. Can't wait to see two of them side by side, the displays on them are epic. I need another pair of 12 inch speakers, one step at a time, still poor and will be for a while even though I'm earning minimum wage (cough).That's Hilarious, I took another look at the photo and it does give an optical illusion of tea-candles. Both units have those markings on the caps, must be a factory thing. I shall be hooking the 2nd unit up to some speakers tomorrow to test, and if it works will integrate it on top of the cabinet. Can't wait to see two of them side by side, the displays on them are epic. I need another pair of 12 inch speakers, one step at a time, still poor and will be for a while even though I'm earning minimum wage (cough).
get something smaller, and run it harder. JBL's always sound best just before they blow up.
You just need to figure out where that is, then back off a notch.
if u can afford to make modest deals, go talk to this guy, and offer him $80.
http://www.ebay.com.au/itm/161044708204?ssPageName=STRK:MEWAX:IT
You can get 'em posted or couriered for less than $20.
They've been listed and failed twice now.
Good advice, thank you. I do have two technics SB-CD933 8's which sound more punchy than my current 12's. I'll message him.
Questions:
1. The pioneer vsx 9500s is rated at 125 watts per channel. Does this mean that all 4 main channels deliver 125 watts?
2. Would it be an advantage if I drive the two JBLs on 1 amp and the two Technics on the other (both are have 8 inch drivers)
Good luck - G knows about speaks!
Questions:
They just requiore more power to be as fast. My 15's are pretty damn quick in the K's.
.... and then the SPL's go up, and up!
Plus I was just trying to make suggestions that would keep within Derek's budget Lee.
He sounds as poor as I am.![]()
World class clean power is only a WOPL away...
You might be very surprised come Christmas.............................
I can't see very well anymore, and my hands tremble too much to use an iron![]()
Just get some good magnifiers for the eyeballs to see what you're working on. I've read that most people's hands shake out of phase so if you hold the item you're soldering with your left hand and solder with your right (I'm assuming you're a righty) the area that you're attempting to solder doesn't move relative to both hands. Simple! Nice clean joint everytime.![]()
