grapplesaw
I will need to creat a score card for this shootout. I find just AB between two cartridges can give great comparison if values are same. The issue is when you have to adjust The volume and of coarse that doesn’t work well. I also want to listen a select few records on each cartridge from my listening chair. It’s amazing what your memory call tell you doing that.
so a couple of the turn tables need tweaking and are going to the bench this afternoon. Mostly arm level height and minor technical issues
