Big cartridge shootout, well big for me
grapplesaw
Vancouver
I have the big TT cartridge test running with 7 TT ‘s through my new selector box connected to a reworked Carver c-4000 through MM2 input
A mighty Thorens 125mkll with a Decca FFsc4 MI cartridge is going direct to the Carver on MM1 input. This will be the reference TT as it is truly beautiful sounding set up
The second MM2 input was the MC input and I modified it to match the MM1 input so basically two MM inputs on this unit. This second input has no capacitance to select in the carver ( I disabled the 5 cap switch I installed when building it) and now have 12 capacitance to choices from on the selector box.
some issues to fix but all going good. It’s never easy right?
now the problem is the Decca!!
I haven’t listen to it for some time. I seam to be sitting here with it playing instead of doing my ABC testing. Oh well I’ll get there. By the way it does sound really good, oh right I already said that.
I have the following on 5 PL 8000 linear tracker’s
Shure v15 4 OEM byrellium cantilever and ? Stylus could be elliptical, hyper or even Micro ridge
shure v15 4 with new micro ridge and boron cantilever
shure v15 4 with cheap elliptical aftermarket
Shure V15 3 with OEM stylus-probably elliptical stylus
Signet TK9 with new line contact nude stylus on tapered aluminum cantilever
also
pioneer pl l1000 linear tracker with
Shure v15 4 and new nude micro ridge on boron cantilever. This is not operating yet
and a pioneer pl-600 long S arm (10”)
It has a pioneer 600 cartridge at this time
cartridges in the line
Stanton EEE 681 MI
Pickering 4000 MM with elliptical needle
Pickering 3000 MM with its special stylus
Technicraft 1000 with conical stylus ( don’t w
right this one off to fast)
Shure 1200hpr
Shure whlb
e30m3mon
Hudson Valley NY
also
Stanton EEE 681 MI
Shure 1200hpr
Shure whlb
You know you're a madman, right ?! :) :) :)
But we share your therapy !
Well done, my friend !
grapplesaw
Vancouver
First shure v15 3 against the v15 4 beryllium
on two linear trackers playing crime of the century which is a older well produced record and I have two for AB
It seams the 3 has more gain so sounded better off the bat. After tweaking A B with volume changed to similar outputs
3 has more Bass and not as much highs
4 is not bad with full range
3 is winner with slight edge
now going to try 3 against Decca
the 3 again has more bass but missing highs of the Decca
4 beryllium and Decca are very similar but not equal
now the real test with a new 4 micro ridge and decca
you know what I said about the Decca sounding good well this 4 thing knocks it out of the park.
has all the bottom end of the 3 great mids and highs of the Decca
Next is 4 Mr against the 4 beryllium
the Mr has more output similar or better than the No contest against the other two v15’s and overall winner this round is the V15 MR very full throughout
I thought the Decca was good across the board neutral I guess best way to say it
It is 40 years old so not too bad but the new 4 Mr is outstanding
now to the clincher
4MR against the Signet tk9 line contact
both just broke in new stylus.
the signet is a special cartridge . Its hand-wound coils and the new upgraded stylus make it excellent for newer records.
so playing now
The 4MR had way more output so having to adjust volume a bit
The 4MR again has more bottom end but not much. The better separation gives the Signet a slight edge over the 4MR
other records will give different reviews for each cartridge I think
I’m done for today
mr_rye89
Land of Entrapment
Lost in the Ozone Again
One helluva shoot out IMO. Now we know what that switch box is for. I also like that 80s/90s entertainment center as a turntable rack.
I’m gonna try out the phono pre in my Carver and see if I like it……
Glen: That's a record # of turntables available with a turn of the knob through your new phono selector switch box. Lots of work to arrange this cartridge shootout - thanks. A premium stylus on the Shure V-15 IV can make all the difference in the world for performance. Nice to see the V-15 III in the shootout. I have a few turntables using this cartridge.
NeverSatisfied
Houston Texas
A man on a mission…..find what sounds best to YOU !!!
A worthy endeavor, especially in a hobby that many just drink the cool aid of others.
The varying output gain is a real obstacle and I found using a SPL meter helpful in getting a more accurate comparison.
Your switch box is the real genius here, not having to setup each cartridge between listening sessions keeps the sound memory fresh and allows instant back and forth comparison.
Well done Glen.
The Shure 3 v Sure 4 is of keen interest to me but I’ll absorb whatever you publish.
This is one of the most useful posts on this site, and I suggest it be made a “sticky” for the future.
grapplesaw
Vancouver
Jim after a lot of reading from various sources , forums and retippers I went to Andy Kim for the Shure MR boron repair. Email him at needleclinic@gmail.com
he was not cheapest and far from most expensive
here is one of his answers to me
solid material boron, sapphire or aluminum is ok for retip but
the tube type cantilever beryllium of a Shure V15 can not be retipped as it will be crushed into particles when you try to retip on it. Boron is the best replacement, and you won't tell any difference in sound anyway.
Repair/Retip will be performed right on my table, nearby Sacramento California,
Unlike other retippers in US (including ebay , they just send customers cartridges to other specialist overseas and it takes several weeks to months back and forth) , none of my repair is farmed out ,
thus very fast turnaround time , mostly 1 day
Paypal invoice will be sent when repair is completed.”
it cost $390 ea with a discount for doing 2 stylus at one time.
