Being Objective
Objective is asking why?
Subjective is saying these are going to sound great. Even though I haven't heard them yet.
I'm listening to the Goldring. Wondering does it really sound this good. Does it sound 600.00 good. Would I even try to replace the stylus? Would I recommend it? If it sounds as good as I think. What can I do to get it even better?
Well, you could get a microscope to adjust VTA and check the stylus rake angle (SRA) to try to match lathe cutters 92degree angle. Then check the stylus azimuth with something like the Fozometer, along with a test LP to ensure proper channel balance. A record clamp and a ring clamp should also be used. You might be able to form more objective opinions about the subjective nature of carts if the level of setup accuracy can be perfected.
